Drag Racing NMRA | FFW | WFC | Rules | Safety | Setups | Hardware | Methods | Timeslips | Records
tires or converter first?
Old Mar 16, 2006 | 02:22 PM
K Bo's Avatar
Launching!
Default tires or converter first?
I am looking at getting a set of 17x9's w/ some 275/40/17 ET Street radials AND a 3200 PI converter. Which should I get first? I know that I can still get more out of the launch on the stock converter on tires and the converter on street tires will really do me no good. I think I have my mind made up, but I just want some other opinions. Thanks!
Kevin
Old Mar 16, 2006 | 02:41 PM
Troy Carter's Avatar
I would get the converter first. Getting the converter first forces you to realize that you will need more tire where as getting the tires first doesn't really provide you with much gain any way you look at it. Plus a converter with stock tires can be fun on the street hehehe.
Though...I would want something around 4000 rpm stall for my street car!
Old Mar 16, 2006 | 02:47 PM
K Bo's Avatar
Launching!
4000? Please explain. Thanks!
Old Mar 16, 2006 | 05:31 PM
TJs98GT's Avatar
Captain Redbeard
id go with a converter first too, if you buy the tires first then by the time you have enough saved up for the converter your only gunna need tires again!
id go no smaller than 3500
Old Mar 16, 2006 | 06:56 PM
K Bo's Avatar
Launching!
I was thinking about going with a loose converter, I just didn't know how loose.
Old Mar 16, 2006 | 07:25 PM
Larry's Avatar
Corvette & Mustang Moderator
Peak torque on our 05/06 stangs is 4500 rpm. For maximum performance you want a converter approximately 500 rpm blow peak torque. Go with a 4000 stall for maximum performance. PI makes a 3600(#7 pump) which would be a good one for our cars. As you add more torque that 3600 might become a 4000.
But to answer your original question, you will probably need sticky tires if you get the converter first. Particularly in first gear. But even on radials from a roll at any speed it is a lot more fun than the factory converter. Mine falls on it face on the 3-4 shift. That wouldn't happen with the right converter.
Old Mar 17, 2006 | 07:35 AM
Right!
With the lockup feature of these newer transmissions there really isn't a big advantage to not using a larger stall. I you will need to footbrake this thing to at least 3500 to get it to leave somewhat well, and higher if you really want to have impressive numbers IMO.
Old Mar 17, 2006 | 12:47 PM
K Bo's Avatar
Launching!
Awesome! Thanks for the info, looks like you guys just made up my mind.
Quick86
Aug 21, 2006 11:53 PM
Larry
May 25, 2006 10:05 AM
1jfuddle
Apr 27, 2006 09:19 PM
Larry
Apr 20, 2006 06:31 AM
K Bo
Apr 6, 2006 12:47 PM
