This 06 Stang needs a converter badly!
Old Apr 18, 2006 | 02:46 PM
Larry's Avatar
Corvette & Mustang Moderator
Default This 06 Stang needs a converter badly!
Looking back at my log of a pass last week I see where after launch I'm going over 30 mph before reaching the advertised peak torque of 4500. I reached 4520.8 rpm @ 31.08 mph. It feels like it too at launch. No wonder this car won't 60'.
On the good side, I'm reading 30.75 degrees of timing at that point. No less than 30 the whole way.
On shift extensions, 1-2 drops to 4857 rpm, 2-3, 4344 and 3-4, 4212. It feels like it's falling on it's face on those last two shifts.
I don't have a recent of my Camaro's but I believe at launch it's around 3800 rpm with no less than 5200 rpm between shifts. I have a PI 3600 converter in it.
This stang would greatly benefit from a loose converter.
Old Apr 18, 2006 | 05:25 PM
BLKWS.6's Avatar
Banned
The mustang has a flat timing curve after something like 5,000 rpm or so I belive.
Old Apr 18, 2006 | 06:32 PM
Larry's Avatar
Might mention too that I have SCT tuning so my timing is a little more than stock.
Old Apr 18, 2006 | 09:09 PM
unit213's Avatar
Administrator
How loose are you thinking...3500 or so?
Old Apr 18, 2006 | 09:32 PM
WILWAXU's Avatar
Should be interesting to see how one reacts to a good stall.
Old Apr 18, 2006 | 10:00 PM
Larry's Avatar
If the factory torque rating is correct and I don't have any reason to believe it isn't, then we will need a 4000 stall for best et. You want your stall 500 rpm below peak torque.
In reality I feel the PI 3600 would be a great converter for our automatics. I would not get that TCI 3000. Just not loose enough. I've had good results with my Camaro although it needs a little looser for max et. But I do drive it on the street on occasion and to the track 54 miles one way.
Old Apr 19, 2006 | 08:19 PM
K Bo's Avatar
Launching!
I have a PI 3600, I am just waiting to get off of nights to install it. Previous best before was 13.46@102 with a tuner only in November.
Old Apr 19, 2006 | 09:42 PM
Larry's Avatar
Seeing as you don't have time to put it in send that puppy to me!
Old Apr 19, 2006 | 10:18 PM
K Bo's Avatar
Launching!
ONLY if when I am ready: you pull it out and install it in my car in perfect working order.
Old Apr 20, 2006 | 06:31 AM
Larry's Avatar
Ok, bring it over and we will stick it in. But be sure to bring two, one for each of us.
You are going to like the performance after you get it in. No more lag at shift. And at any speed when you punch it it will go. You are going to need some sticky tires though!
haxorbarr
Jan 26, 2008 07:21 PM
bayer-z28
Dec 27, 2006 11:23 PM
1jfuddle
Apr 27, 2006 09:19 PM
K Bo
Apr 6, 2006 12:47 PM
K Bo
Mar 17, 2006 12:47 PM
