Mustang Boosted List?
lets see what you 'stangs are doin
Car: Motor: Trans/Clutch/Gear: Kit: Dyno: ET's: post em up guys :) |
03 Cobra
2.8 pulley ported eaton solid axle 3.90s and ET streets 11.40@122.33 In the process of a 21 psi Whipple swap :drive: |
Car:1989 Mustang GT
Motor:Stock short-block, GT40 Irons heads, TFS Stage 1 cam, Edelbrock Performer Intake Trans/Clutch/Gear:Stock T-5, Centerforce DF, 3.55 Kit:Vortech T-Trim 3.00/8.0 Dyno:488 rwhp 475 rwtq 10# on the old S-Trim setup ET's:12.20@116 with stock motor and A-Trim no new times |
91 Mustang
A little bigger than stock ;) Powerglide Modified HP last year 750HP and 9.30's...this year ??? |
Hey Ben, did you ever sell that '76?
Yeah it's long gone.
Car: 92 coupe
Motor: stock 302 w AFR185 Trans/Clutch/Gear: T-5 Kit: S trim Dyno: 5xx ET's: 10.75 @ 132 On Pump gas!!! plus the car still had A/C PS full interrior. But its has changed sence then. We will see what this year brings. Paul |
93 Notch
Stock 302, stock heads, comp 276 cam, 1.72 rr's, GT40 Intake, 65mm tb, 73mm blow through C&L, 30# injectors, aeromotive AFPR Stock flywheel, centerforce dual friction disc, cobra pressure plate, stock T5 8.8, motorsport trac loc, 28 spline 5 lug, TA girdle Boost: Home made setup, twin T04B15's, Vecco (2)2.5" in (1)3" out updraft intercooler, twin tial 38mm gates, up pipes are modified mac shorty headers flipped and chopped, downpipes are 3" to vortex mufflers dumped at the diff. ET: 10.9 @ 127 on pump and drag radials full interior 14 psi boost and whys the forced induction category only in modular.... what us pushrod guys cant have boost? |
2000gt
t45/spec3 T-trim mongoose from mph 380/384 |
03 Cobra
2.93 pulley non-ported eaton solid axle 3.90s and ET streets 428/430 on a Mustang Dyno 11.4@120 on a 1.60 18lbs and 75 shot this year on a ported eaton and car weighing -3300 |
| All times are GMT -5. The time now is 06:19 AM. |
