Forced Induction Superchargers | Turbochargers | Intercooling | Water/Methanol Injection
2 instead of one?
Old Jul 13, 2008 | 10:20 AM
kaboom10's Avatar
Staging Lane
Default 2 instead of one?
I wondering if any one used 2 turbos rated for like a 2.2L engine. Should it be giving the same capacity of one turbo for a V8? I have a 5.4L so would a couple of small turbos work?
Old Jul 16, 2008 | 11:58 PM
metalmover's Avatar
With small turbos the max effciency point peaks early. This gives quick boost responce at the extreme expence of high back pressure and high intake-charge temp. To keep intake-charge temp down larger turbos are necessary. Cooler temps mean denser air,which keeps torque peaks at higher RPM's. Nether set up is bad it depends on how you want it to peform.
Old Jul 17, 2008 | 06:38 AM
kaboom10's Avatar
Staging Lane
Thanx for the info. It then sounds doable. I hardly get over 4 grand and I've got a 4.56 rear.
Nine Ball
Jun 11, 2006 09:07 PM
Nine Ball
Apr 25, 2006 04:07 PM
Larry
Apr 25, 2006 08:20 AM
Robert B.
Apr 11, 2006 10:18 PM
BAD FNZ
Apr 2, 2006 12:15 AM
