FOX body help GREATLY NEEDED!!!
Old May 26, 2006 | 11:46 PM
blue99SS's Avatar
Default FOX body help GREATLY NEEDED!!!
My buddy needs help with his fox body stang. In his words.
I have recently installed a crankcase evac pump on my 91 GT. I can't keep the catch can from spraying oil when it's not even full. I have had the pump suction tube installed on the valve cover, the back of the intake, and even had a custom baffle system made on the bottom side of the intake so it wouldn't suck oil anymore, and it is still is doing the same thing. I am running a motorsport evac pump and I have a moroso check valve set at 6 inch pounds at idle. I thought this custom baffle system on the bottom of the intake would work, but something is not right. I have the moroso catch can mounted on the frame rail about a foot from the pump, and overflows when not even full.
Old May 28, 2006 | 12:03 PM
This might sound stupid, but is he sure the connections on the catch can aren't reversed?
josh99ta
May 16, 2006 03:46 PM
y2k_ta
Apr 28, 2006 08:46 PM
Torque_Wrench
Apr 28, 2006 11:39 AM
MillaTK
Apr 12, 2006 08:08 PM
Apr 3, 2006 01:06 AM
