Clutch Resource Thread
Old May 23, 2006 | 07:37 PM
Default Clutch Resource Thread
The purpose of this thread is to help someone who may be switching out the stock clutch for an aftermarket unit.
For those of us who have replaced the stock Clutch, what did you go with, and what were your reasons.
I have a Spec 2 in my GT. I didn't want just a stock replacement since I planned on running slicks and didn't want to destroy the new unit. The pedal has a slightly heavier feel vs stock and even some other replacements like the king cobra clutch, but I liked a slightly heavier clutch pedal.
Old May 24, 2006 | 10:20 AM
Bitemark46's Avatar
11 Second Club
I HAD a Centerforce Dual Friction. A little stiffer than stock. Slipped on it's maden voyage on drag radials. Didn't last but 5k miles. Went to a spec stage 3. A little stiffer than the CF DF. No slippage. Lightswitch clutch. But it friggin grabs. Tons of passes down the strip and still chirps 4th w/ 26x10's. No really street friendly. -Mark
Old May 24, 2006 | 10:58 AM
SJRTX's Avatar
I had a Centerforce DF and pulled it out after 10k miles due to some strange problems. It might have been or clutch or not. Cant see anything visually wrong with the clutch though.
Anyhow, it chattered, and the weights were noisy as ****. I replaced it with a King Cobra (I have a dual pattern flywheel so I can swap between 11" and 10.5" clutches if I want), and I like this King Cobra much better. I expected pedal feel to be much worse, but I think a lot of people that complain about them do not grease the clutch fork pivot ball. Clutch pedal isnt much harder than the centerforce.
Old May 24, 2006 | 06:30 PM
A lot of people look over this, it is very important to get a nice wire brush and brake cleaner and get the pivot ball nice and clean, then cover it and the socket for it on the clutch fork with fresh grease. it work wonders
Top Fuel Friday
Apr 1, 2008 09:10 AM
Jun 3, 2006 05:48 PM
383ss
May 3, 2006 12:56 PM
blueeyeddevil
Apr 28, 2006 08:44 PM
383ss
Apr 12, 2006 03:25 PM
