bad gauge?
my car seems to be down a bit on power. I just filled my bottle and the gauge only reads 650PSI with the bottle heater on. Is there a way to test the gauge on my bottle?
Thanks, Tom |
Thanks, Tom I would just get another gauge and see....better safe than sorry....I've seen a car that hurt some parts because of a "faulty" gauge... Where are you located??? I have an extra one you can use to test with if you are local... |
Originally Posted by LS1 KLR
Hmm...a full bottle that is warm should be way more than 650 psi....
I would just get another gauge and see....better safe than sorry....I've seen a car that hurt some parts because of a "faulty" gauge... Where are you located??? I have an extra one you can use to test with if you are local... Thanks for the offer but I'm in southern CA. Tom |
Take the bottle out of the car and weigh it. The weight of the bottle when it's full will be engraved on the bottle or on the label. If the bottle is at full weight then you know you have a bad gauge. If the bottleis underweight then you know your gauge is ok.
ill give that a shot! thanks Tom |
| All times are GMT -5. The time now is 06:20 AM. |
