My new build for my 95 Gt
Old Nov 22, 2006 | 06:20 PM
chipa@epp's Avatar
Default My new build for my 95 Gt
My car was pretty quick with the stock block 347, but the stock block was on the edge, so here's the new combo going together. I just picked up a Dart Iron Eagle race block (all 5 mains 4 bolt) and a forged scat crank and rods with JE pistons to build a 427 windsor. It will be a solid roller cam motor with either TFS cnc high ports, or AFR 225s. Open to suggestions on that. I plan to run either a Edelbrock Victor 5.8 with a 2 stage gemini setup or a super victor with a direct port system. Also open to suggestions on that. I'll be spraying a total of around 300hp. I have a Lentech trans now with a PI triple disc stallion converter now that stall at 4200 that I'll probably find the life expectancy on. I want it to make peak power at about 7000 to 7200 so I can shift it at about 7500. It will have the full UPR pro rear suspension with a built 8.8 with 9" ends 3.73s and a spool. It already has QA1s all around and a tubular front. As you can guess, this won't be my daily driver, but it will be driven. Let's hear your opinions and comments!!
Old Dec 17, 2006 | 08:18 PM
Altec's Avatar
Damn, sounds like a hot set-up. should be wicked.
what hp numbers or ET you shooting for?
Old Dec 18, 2006 | 10:57 PM
chipa@epp's Avatar
I'm hoping it will go deep into the tens on the motor and into the nines on a single stage. As far as hp #s, with the high stall, who knows? 6xx on the motor?
What's your guess?
Old Dec 18, 2006 | 11:13 PM
Altec's Avatar
i would guess somewhere in the 600 range... thats going to be a sick set-up. Whats the final compression going to be? Shouldnt have much for street manners.... lol
Old Dec 20, 2006 | 10:30 PM
chipa@epp's Avatar
It's going to be 11.2 to 1. Street manners be damned!
bigbass1307
Aug 5, 2010 07:32 PM
dan03mach
Jun 5, 2007 07:23 PM
