What are the pros/cons to supercharging a cammer 5.0
Hi guys
I am new to this forum and wish I had found it earlier. My story so far- I bought a 03 Terminator which was accident damaged even down to ripping a chunk out of the block. It did however come with a KB 2.2l Blower. I have tried to source a block for some time but as I live in England, it has proved to be a royal pain. A slightly damaged Cammer 5.0 has now appeared and I have a couple of questions.
1. Can I buy new cylinder liners for this engine?
2. If so, any idea of cost?
3. How hard is it to change them over?
4. Should I leave the motor na or should I swap the pistons out for lower compression and throw the KB on there. (Pros and cons please)
I am looking forward to using the site often, so hello to you all, Paul.
Have a look here.....http://www.modularmustangracing.com/...hortblocks.htm I'm sure they can help with shipping if needed and they can make sure you are set up right.
