RAISING compression on an 05+ mustang
Old Aug 23, 2006 | 07:19 PM
383ss's Avatar
10 Second Club
Default RAISING compression on an 05+ mustang
ok, 9.8:1 is great to run 87 octane and get decent boost, but it blows for NA.
I want to raise the compression to 11 or 11.5:1
here's the info I need.
stock combustion chamber size and how much milling effects it.
what is the compressed thickness of the stock head gaskets and are any aftermarket gaskets available??
when do you run into p/v clearance issues on stock cams? I have no problem fly-cutting the pistons if necessary.
Old Aug 25, 2006 | 12:49 PM
triumphman's Avatar
Milling the heads would require machining the front timing cover also,the best way to raise compression would be a set of flat top pistons to replace the factory dished piston you would gain about 6 cc's. The factory gasket is .033 crushed and pistons are aroud .008-.010 down so a thinner gasket isnt a option. I havent checked p to v with larger cams but I will in the near future as I am having cams ground very soon..
Old Aug 27, 2006 | 10:20 AM
383ss's Avatar
10 Second Club
thanks for the info please keep us informed on what you find out about the cams!!
don't suppose you know the DRC stock?
any idea how much milling the heads effects chamber volume?
from my info, stock CC is 51.1
Old Aug 27, 2006 | 10:29 AM
383ss's Avatar
10 Second Club
ok, this is pretty close. gives 9.9:1. thought stock was 9.8:1 though.
3.55 bore, 3.54 stroke
-6cc pistons
51.1 cc heads
.009 below deck
gasket .033 crushed
Old Aug 28, 2006 | 11:15 AM
triumphman's Avatar
There are production tolerances I have cc'ed chambers that are from 50.5 to 51 .7 deck heights very also. I would say when it comes to resurfacing the heads every .005 removed should net -1cc. Dont know what the dcr is.
Altec
Feb 1, 2007 03:43 PM
