-   -   Max Horsepower with a stock bottom end 4.6? (https://www.modmotortech.com/forums/internal-engine-20046/max-horsepower-stock-bottom-end-4-6-a-252/)
5.0N20 Apr 11, 2006 12:19 PM
What's the most horsepower ever achieved by a stock bottom end 4.6 soch mustang with forced induction (turbo/sc)?
Top Fuel Friday Apr 11, 2006 07:03 PM
it's just not the power you make, but the condition of your bottom end and the quality of you're tune.
On that note if everything was perfect, in a perfect world, the rod's are going ti give out at around 450 wheel hp, and the cast crank is good to around 600 wheel horsepower. More is possible but it is severely damaging to your stock block, and will kill the longevity of your engine.
BWH2003 Apr 12, 2006 01:50 AM
It also depends on year of the car. The 2003-2004 cobra can handle up to 600 horsepower before the pistons will take a dump.
Top fuel is right on if its a pre 2003 4.6 L motor.
Shane97Cobra Apr 12, 2006 10:18 AM
The stock SOHC 4.6L motors start to have problems just above 400 RWHP. The piston ring lands seem to be the first to go.
Top Fuel Friday Apr 12, 2006 10:52 AM
He isn't talking about a DOHC (cobra) motor, which has a different bottom end than the SOHC (GT) engine.
Any cobra engine is going to be able to handle a lot more power than the GT counterpart, due in large to their 4 bolt mains, and forged crankshaft.
BWH2003 Apr 12, 2006 11:33 AM
Yeah I missed the sohc part. Sorry :bang: :twak:
Bitemark46 Apr 12, 2006 01:25 PM
Cranks don't matter. Both will not be the cause of engine failure below 600hp. The rods and pistons are the same from 96-01 for both 2v and 4v. Powered rods and hypereutectic pistons will fail around 450. Of course there are a few exceptions to the rule. But the ones that I know of already failed. Aka Brian Bradford's stock bottom end 4v. 603rwhp. -Mark
RussStang Apr 15, 2006 03:54 PM
Another vote for 400-450rwhp before the pistons/rods give out.
Top Fuel Friday Apr 15, 2006 10:26 PM
Definitely 400-450 is the limit for the stock rods / pistons. Powered metal for the loose
cleveland Apr 16, 2006 12:27 AM
yeah, same thing goes for the 3v engine but there are also plenty that are still living with higher than 450rwhp numbers. It isnt a perfect world and not all engines are created equal.
The other question is... will 600+ ft/lbs kill my 5 speed automatic?
-Dan
