General Maintenance & Repairs Oil Changes | Leaks | Squeaks | Clunks | Rattles | Grinds
Trick to changing 5.0 Fox Body Oil?
Old Apr 4, 2006 | 11:31 AM
y2k_ta's Avatar
'Bird Director
From: Central Indiana Honors: 4th grade spelling bee contestant
Default Trick to changing 5.0 Fox Body Oil?
I've helped my brother change the oil in his '92 5.0 a few times, and for the life of me can't figure out how to do it with my floor jack still underneath the car. I'd rather leave it under there even with jackstands for extra support (I'm trying to be a good example to my brother on doing it safely), but the floor jack is in the way of placing the oil drain pan under either of the drain plugs. I've got your average round drain pain, but it's not working well. In fact, I've got three different sized drain pans the I've tried with no luck. To do it now, we have to teter the pan on the wheels of the floorjack while I squeeze my hand between the car's oil pan and the tetering drain pan to take the drain plug out. It's a two person job.
Is there a special pan you guys use, or does everyone just put their car on jackstands and pull out the floor jack? I've considered modifying a drain pan to work, but wanted some expert advice first. Thanks in advance for any replies.
Scott
Old Apr 4, 2006 | 01:04 PM
I guess I'm lazy. I pull the car up on ramps and let 'er rip
Old Apr 4, 2006 | 01:40 PM
Ramps work great, If you're wanting to use jack stands, you could jack it up a lot higher and put the stands on the frame rails right under the doors.
Old Apr 4, 2006 | 02:39 PM
Blue91's Avatar
I jack the car up and use jackstands. With a good set of stands, I don't see the need to have the jack under there as well.
Old Apr 4, 2006 | 06:07 PM
Speeds8erM-1's Avatar
TECH Enthusiast
Yep! Dont forget there are two plugs on the pan also, this is foreign to some people coming from GM's, was for me anyway.
Old Apr 5, 2006 | 06:14 PM
y2k_ta's Avatar
'Bird Director
Thanks for all the responses! I honestly never thought of using ramps. I'll probably just go the jackstands/no floor jack route the next time. Yep, my brother mentioned the two drain plugs before we even started, and it's too bad that the front sway bar is right in the way of the exiting oil on the front plug
Old Apr 5, 2006 | 08:29 PM
Steve-099xlt's Avatar
That it is! I can't count how many times that has made me mad when doing an oil change on a fox!
Old Apr 6, 2006 | 01:41 AM
BWH2003's Avatar
The best would be to have access to a lift. It is so much easier but if you must ramps are the easiest way. Or you could jack somewhere else than the motor.
Old Apr 6, 2006 | 05:46 PM
TECH Enthusiast
Yep, stuff goes everywhere, then the sway bar starts to collect dirt and grime.
Old Apr 16, 2006 | 03:10 PM
BLKWS.6's Avatar
Banned
Floor jack? I change the oil in my 5.0 on a level drive way with all 4 tires planted. It takes a long arm and decent muscle to tighten-untghten the drain plugs at full arm extension, but i have a deathly fear of getting under cars after watching one come down on my grandpa (shitty hydrolic and he wasnt thinking and had no safety jacks). Anywho, works for me, get both the front and rear plug and filter just fine.
