Forced Induction Superchargers | Turbochargers | Intercooling | Water/Methanol Injection
4.6 turbo options?
Old May 31, 2006 | 12:57 AM
Wnts2Go10O's Avatar
TECH Junkie
Default 4.6 turbo options?
ok, ive been thinking about this recently. would the SOHC/DOHC issue effect choice of turbo? in some way does the valvetrain differences create a difference in the characteristics of the turbo spool and power curve? anyone maybe hve a dyno sheet from each with the same turbo for comparison?
Old Jun 1, 2006 | 05:14 PM
Saleen91's Avatar
see www.turbochargedpower.com and proturbokits.com
Both make 4.6 kits. There's also a few more companies. B&G Fabrication in Ohio, and some company who's name I can't remember in New Mexico also makes a nice kit for the 4.6. I'd suggest putting in some calls to those companies and see what they recommend.
Old Jun 2, 2006 | 09:51 AM
Blue91's Avatar
Hellion?
Old Jun 2, 2006 | 09:58 AM
Saleen91's Avatar
Ahh good point. I forgot about Hellion. Supposedly nice kits, polished stainless on the cold side, and they re-use your factory headers to save a little on cost.
Old Jun 2, 2006 | 11:45 AM
unit213's Avatar
Administrator
Hellion.
Old Jun 3, 2006 | 12:23 PM
Wnts2Go10O's Avatar
TECH Junkie
you arent getting the question... would an sohc and dohc with the same turbo act differently in terms of spool, power curve, and why?
Old Jun 3, 2006 | 01:53 PM
Saleen91's Avatar
I would assume they would act differently. One is a lot more efficient at moving air than the other. So in essence you should be able to make the same RWHP with the DOHC at less boost than what you could with the SOHC.
Old Jun 5, 2006 | 12:42 PM
Bitemark46's Avatar
11 Second Club
SOHC would probably spool up quicker due to only having one intake valve and lower CFM#'s as compared to a DOHC head. But on the flip side the DOHC would probably pull to 7k or higher where as the SOHC would be already dropping off at that point.
I agree w/ Saleen91, DOHC would make the same#'s w/ less boost but it would make the same peak power at a higher rpm. Same goes with the peak torque #'s too. But for a street car setup I wouldn't think the size of the turbo would be different. Now purpose built race car it probably would. I would put a bigger turbo on the 4v then the 2v simply cause the 4v moves more air (obviously). -Mark
carid
Sponsor Specials & Group Purchases
Jan 14, 2015 04:05 AM
gyrene2003
Feb 19, 2009 02:21 PM
truedeath
Jun 9, 2008 03:31 PM
kapedogg
Sep 22, 2006 10:09 AM
baddogz28
Aug 21, 2006 02:07 PM
