how much horse can i expect to get
Old Dec 28, 2007 | 09:55 PM
tcwebb's Avatar
Default how much horse can i expect to get
hey i have a 99 ss. its an automatic and its completely stock. in about a month i want to start putting some money into it. im willing to put about 2 grand into. the only thing is i want as much horsepower as i can get without burning my engine up so fast. i was thinking something like headers, exhaust system, air lid, air intake? is there anything i can do to give me a pretty good amount of horse without having to rebuild my engine anytime soon. i never take it to the track and i only street race occasionaly. i wish i could get about 400rwhp or at least close to it. any ideas?
Old Dec 29, 2007 | 01:52 PM
kaboom's Avatar
Registered User
Add a nitrous system for extra horses ez. Make sure you get a reprogrammer too. Just get the bolt ons and a gear change should cost about 2k. Still get the programmer as you need to change for the gear change.
Old Dec 29, 2007 | 08:51 PM
tcwebb's Avatar
i would get the bottle but wouldnt i have to get all performance parts in my engine before i did that. if i just leave the factory pistons and pushrods and all that will it not screw my engine up? i thought it would burn up unless you had stronger parts
Old Dec 29, 2007 | 09:31 PM
kaboom10's Avatar
Staging Lane
You can add some horsepower to a stock motor. Roush has a bolt on for over a hundred horses on a stock motor. It's when you get too many ponies going for what the factory built. The stock mod motor rods are a weak link. Anything serious means another short block to handle it modified with pistons and rods replacements. Then there's power to be made with cylinder heads. If you supercharge you can get away with minor work since the blower pushes in the extra air. If you remain normally aspirated you need a lot of head work along with a cam change. This requires a tuner to modify you stock parameters to operate with the performance increase. You can add nitrous with or without head mods but with a cam change. Nitrous is a oxidizer that requires extra fuel to keep from burning the engine. If the extra fuel isn't delivered you have an instant boat anchor. I hope this helps you out or kept you amused and confused. LOL
Old Dec 30, 2007 | 12:50 AM
tcwebb's Avatar
haha yeah i semi-understand thanks. i plan on putting about 2 grand in. i just dont know whats best to do without having to worry about burning up my engine up so fast...just trying to get some suggestions
Old Dec 30, 2007 | 02:05 AM
tcwebb's Avatar
if you had a stock ss and someone gave you a couple thousand dollars to drop what would you do
Old Dec 30, 2007 | 09:49 AM
kaboom10's Avatar
Staging Lane
2 grand ain't much. I'm hoping to be working with 2-2.5k figure. The following is my choices and the prices of each.
1.SCT tuner $478 plus software program $350 (allows tuning all kinds of parameters) you can get others for around $400. There's a tuner for just changing the rear axle ratio if you want that.
2. 4wd gear swap $1050 and this will give you a lot better acceleration.
3. Cold Air Intake $220 but the replacement filter for a stock setup is $35-$55
4. Exhaust cat back $350-$550 but a muffler is about $120.
5. Camshaft(s) As much as $1450 for a 4v pr of heads or half for 2v heads. A single cam I would think would be about $350
2k don't go very far. Buy a bunch of lotto tickets and hope to double your money LOL
Old Dec 30, 2007 | 01:15 PM
tcwebb's Avatar
haha yeah ill try the lotto thing and see how it goes. if i hit powerball well split it haha. naw dude im just a 19 year old kid in college i cant afford to spend a whole lot in it yet. after college i can but not yet
Old Dec 30, 2007 | 06:00 PM
kaboom10's Avatar
Staging Lane
I see you believe in the lotto like I do. I never lose cause I never play. Well a good tuner will let you optimize what you have before you make any decisions as to what is next.
ThrottleHappy7
Feb 15, 2007 12:27 AM
NIRVANA
Jun 29, 2006 01:41 PM
klmracing
Jun 7, 2006 09:48 AM
Larry
Mar 7, 2006 03:12 PM
