Ok, lets hear it, what have you broke at the track?
Ford or Chevy.
I broke my drivers side axle bearing on DR's (when my rear was stock) then a different time I managed to weld my pressure plate to the disk. Wifes car- spark plug boot came off. :eyes: :jest: Anybody beat that? :drive: -Mark EDIT: oh and managed to rip my airbag in my rear suspension. :confused: sounded like there was a snake under my car. |
I've broken my whole car! Wrecked my 88 just past the 1/8 mile a couple years back. Parted the car out.
I broke the gears in the Formula, but managed to drive it home and fix it :)
I broke my output shaft in the trans then pushing up on the trailer it rolled off the ramp and cracked my fender. Not a good day!!!
With my present car...3 trannys, 2 torque converters, 1 rear gears, 2 differentials, lifted the heads twice.
Nothing. Just always at the track with friends when they break :D
In my 05 :bang:
I spread the stock differential as well as an Auburn Pro after 4 passes. Tru trac is the way to go in this car. Ate up one set of gears too. I managed to pull the carrier bearing support on the 2 pc. driveshaft off of the body (at launch) which lengthened the drive shaft, shoved everything forward, cracked the bellhousing as well as about 8 cracks all around the rear of the block. I've also broken the shifter linkage slamming gears. Roasting the stock clutch is a given :drive: I think that's about it. I can't seem to recall anything else at this time. |
Damn, that thing must launch hard. What kind of 60' times are you getting out of it?
Leaving at 6K, I was only getting 1.6's. Once I finish up the turbo install, it should get into the 1.4's.
The sad thing is that I was getting 1.8's on stock tires (Pirelli P Nero's). |
my old coupe broke a stock axle on street tires... ended up needing a new diff after the axle mushroomed to where we couldnt get it out :( thankfully blue91 (fred) and a few other of the guys were there to help with taking it apart and after a few days putting it back together! :hail: after it broke i kept going and ran my fastest pass of the day with my wheel sticking half way out on the big end lol
fotgot to say i also destroyed 3rd gear in that car and a set of fms gears on the car i have now |
