-   -   Clutch Resource Thread (https://www.modmotortech.com/forums/chassis-drivetrain-27/clutch-resource-thread-495/)
Top Fuel Friday May 23, 2006 07:37 PM
The purpose of this thread is to help someone who may be switching out the stock clutch for an aftermarket unit.
For those of us who have replaced the stock Clutch, what did you go with, and what were your reasons.
I have a Spec 2 in my GT. I didn't want just a stock replacement since I planned on running slicks and didn't want to destroy the new unit. The pedal has a slightly heavier feel vs stock and even some other replacements like the king cobra clutch, but I liked a slightly heavier clutch pedal.
Bitemark46 May 24, 2006 10:20 AM
I HAD a Centerforce Dual Friction. A little stiffer than stock. Slipped on it's maden voyage on drag radials. Didn't last but 5k miles. Went to a spec stage 3. A little stiffer than the CF DF. No slippage. Lightswitch clutch. But it friggin grabs. Tons of passes down the strip and still chirps 4th w/ 26x10's. No really street friendly. -Mark
SJRTX May 24, 2006 10:58 AM
I had a Centerforce DF and pulled it out after 10k miles due to some strange problems. It might have been or clutch or not. Cant see anything visually wrong with the clutch though.
Anyhow, it chattered, and the weights were noisy as shit. I replaced it with a King Cobra (I have a dual pattern flywheel so I can swap between 11" and 10.5" clutches if I want), and I like this King Cobra much better. I expected pedal feel to be much worse, but I think a lot of people that complain about them do not grease the clutch fork pivot ball. Clutch pedal isnt much harder than the centerforce.
Top Fuel Friday May 24, 2006 06:30 PM
A lot of people look over this, it is very important to get a nice wire brush and brake cleaner and get the pivot ball nice and clean, then cover it and the socket for it on the clutch fork with fresh grease. it work wonders :D
