Nitrous Oxide Nitrous Express | NOS | Cold Fusion Nitrous
spray on a stock long block?
Old May 9, 2006 | 10:38 PM
hardtohitme7's Avatar
Default spray on a stock long block?
allright guys im looking at getting a 4.6 this summer and im looking at a cheap way to make power, the cheapest way is nitrous of course. how much are you guys spraying on your car and what nitrous assessories do you have thanks.
Old May 10, 2006 | 09:00 AM
A little bird once told me the 4.6L doesn't mind 250HP worth of nitrous
Old May 10, 2006 | 10:24 PM
Gold Z's Avatar
TECH Fanatic
You would have to be braver than I am to spray a 250 shot on a stock 4.6L...........
Old May 11, 2006 | 01:03 AM
Tom's_03SVT's Avatar
TECH Enthusiast
75 dry shot.
heater, window switch,purge, and FPSS.
Tom
Old May 15, 2006 | 01:20 AM
dan03mach's Avatar
9 Sec. Club!!!
The most I would put on the stock block would be a 175 shot and if you ran that I would have NGK BR7 plugs and either race gas or put some torqco in the tank.. I have sprayed a 125 shot for months and a 150 shot for months.. I am about to put the 175 pills in but that is only going to be at the track with some type of higher octain fuel.. Just to let you know Nitrous is adictive and you will up the shot before too long.. If you are going to put it on a GT stang 99-04 I wouldn't put more then a 125 shot due to the plastic intake they have.. I would also get a window swich in it so it doesn't activate too early or stay on too long just incase you hit the rev limiter.. Nitrous can be safe just as long as you do it right and get your car tuned for it.
Old Apr 5, 2007 | 05:05 AM
Ty_Hoe's Avatar
I would say that you are safe with a 150 shot if you upgrade the fuel pump...
Old Apr 24, 2007 | 05:06 PM
Dynotune04's Avatar
125 wet shot is max. The pistons are extreamly hard and the ring land is ver very high on the piston. the hardness of the piston doesnt allow it to take a really hard hit. It will break. Where as a softer piston will be able to absorb the blow. This info is for a 96-04 2 valve mod motor. I dont know how much a 4 valve motor will take (mach 1 or cobra)
FordTruckJAM
Sep 11, 2013 12:28 PM
Sunoco Man
May 3, 2010 05:53 PM
andygap411
Apr 16, 2006 03:26 PM
slowpoke96z28
Apr 5, 2006 07:29 AM
