What cam to run with GT40 iron heads?
Old May 9, 2006 | 11:55 AM
Default What cam to run with GT40 iron heads?
i'm pretty damn sure I'll be using a set of GT40 iron heads here on my motor, and am trying to figure out what cam would mate up well with em. One of the letter cams? I'm trying not to touch the pistons until later down the road when I build a shortblock... Any recommendations? It's a street/strip car that sees more street than strip.
Old May 9, 2006 | 12:42 PM
Thoroughbred's Avatar
If I remember......you posted earlier that you were looking into a blower?
ALOT of people have used blowers with GT40 heads and a TFS stage 1 cam with bad *** results. I personally know people that have used that set up on a stock shortblock, taking into account that your using stock valve sizes...that should clear just fine. But it is always best to check
Other cams Id look at but I do NOT know if they will specificaly clear would be a XE264HR or XE270HR from comp. And of course you could always go custom and make sure you tell em you've got a stock shortblock.
Old May 9, 2006 | 12:45 PM
sweeeeet, I've liked the specs of the TFS S1 cam, just never knew if it would clear with some stock GT40s..
My buddy built a junkyard twin-turbo setup for his notch using stock GT40P heads and put out some nasty horsepower.
Top Fuel Friday
Jul 11, 2006 07:49 AM
Jun 28, 2006 10:52 AM
Apr 17, 2006 12:13 AM
Apr 12, 2006 10:52 AM
| Powered by Satan |
Mar 15, 2006 01:34 AM
