Nitrous Oxide Nitrous Express | NOS | Cold Fusion Nitrous
Nitrous Backfires
Old May 23, 2006 | 07:44 PM
Default Nitrous Backfires
How many guys have lost their stock intake manifold to nitrous back fires? Will an bullitt manifold be prone to breakage like the plastic one, or will it be able to handle such a back fire?
Old May 24, 2006 | 12:01 AM
dan03mach's Avatar
9 Sec. Club!!!
You shouldn't have trouble with the bullitt intake but to keep the car from backfiring due to over rev or coming on to early I would put a window switch in there.. You shouldn't have any issues if you spray between 3400-6000 rpms.. And don't try to put too much Nitrous through it.. I would keep it at a 100 shot maybe a 125 shot but no bigger on the stock intake.
Old Jun 4, 2006 | 02:39 AM
LS1 KLR's Avatar
The Bullit should be able to withstand a backfire more than a stock plastic one that's for sure....but I've seen some pretty serious backfires blow apart some aluminum intakes before...not a pretty site!
Old Nov 15, 2006 | 06:18 PM
MisterGiggleJuice's Avatar
i've seen more than a few 96-98 and 99/01 cobra's blow up their manifold
Old Dec 9, 2006 | 07:00 PM
ITSTOCK's Avatar
Add a window switch and you won't have a manifold blowing off...or up (assuming that you are talking about NORMAL nitrous shot usage).
It's caused by the fuel puddling at low RPMS (not getting sucked in)
Old Dec 24, 2006 | 01:08 PM
Dynotune04's Avatar
Also dont pedal your car while spraying the car stay in the throttle or completely get out of it pedaling the car will cause puddling of gas and nitrous in the intake manifold and that will most certainly cause a backfire
Old Dec 31, 2006 | 01:24 AM
SOMFormula's Avatar
Staging Lane
Window Switch is a MUST for an manual transmission. MSD digital one is a good one. I like the adjustability. Correct me if I am wrong, but can't you do a Direct Port from Dyno tune, and that way you won't get the puddling effect that a shark nozzle (or something similar) will give you? I'm not familiar with Mustangs, but the Direct port I'm looking at from Dyno Tune just puts a little adaptor on your fuel injector, so that you can add the N20 and fuel lines directly to the fuel injector. It seems to be the best "bang for the buck" setup out there for a direct port! Maybe they have a Mustang version?
Old Jan 5, 2007 | 03:35 PM
Dynotune04's Avatar
last time i was at dyno tune the did not offer a set up for direct port for a mustang. i run the dynotune wet kit and havnt had any problems but i havnt been there or talked to them since august
01gtmustang
Jan 1, 2007 08:23 PM
oxfordgt
Aug 26, 2006 11:16 AM
Top Fuel Friday
Jul 19, 2006 07:49 PM
Quick86
Jun 26, 2006 02:42 PM
Gold Z
May 8, 2006 01:01 AM
