-   -   RAISING compression on an 05+ mustang (https://www.modmotortech.com/forums/internal-engine-20046/raising-compression-05-mustang-716/)
383ss Aug 23, 2006 07:19 PM
ok, 9.8:1 is great to run 87 octane and get decent boost, but it blows for NA.
I want to raise the compression to 11 or 11.5:1
here's the info I need.
stock combustion chamber size and how much milling effects it.
what is the compressed thickness of the stock head gaskets and are any aftermarket gaskets available??
when do you run into p/v clearance issues on stock cams? I have no problem fly-cutting the pistons if necessary.
triumphman Aug 25, 2006 12:49 PM
Milling the heads would require machining the front timing cover also,the best way to raise compression would be a set of flat top pistons to replace the factory dished piston you would gain about 6 cc's. The factory gasket is .033 crushed and pistons are aroud .008-.010 down so a thinner gasket isnt a option. I havent checked p to v with larger cams but I will in the near future as I am having cams ground very soon..
383ss Aug 27, 2006 10:20 AM
thanks for the info :) please keep us informed on what you find out about the cams!!
don't suppose you know the DRC stock?
any idea how much milling the heads effects chamber volume?
from my info, stock CC is 51.1
383ss Aug 27, 2006 10:29 AM
ok, this is pretty close. gives 9.9:1. thought stock was 9.8:1 though.
3.55 bore, 3.54 stroke
-6cc pistons
51.1 cc heads
.009 below deck
gasket .033 crushed
triumphman Aug 28, 2006 11:15 AM
There are production tolerances I have cc'ed chambers that are from 50.5 to 51 .7 deck heights very also. I would say when it comes to resurfacing the heads every .005 removed should net -1cc. Dont know what the dcr is.
