New motor build up..
Old Oct 27, 2006 | 11:41 PM
dan03mach's Avatar
9 Sec. Club!!!
Default New motor build up..
I just had a new short block built for my 03 Mach1.. I wanted to make more power then what I was making and I new the stock shortblock would not hold the power I want to put down right now so I went ahead and had a new short block built..
The is a Teskid block, my stock Cobra Crank, Manley H-beam rods, Manley Flattop pistons, all ARP hardware, race bearings, ETC... The block is blue printed, balanced, Decked. All the good stuff.. I have hear these Teskid blocks can hold as much as 1500hp so that should be good for me.. The only thing I could have done better is put Billet Rods in, but those are around 1200 bucks.. Here are a few pics.
Attached Thumbnails New motor build up..-picture-077.jpg   New motor build up..-picture-075.jpg   New motor build up..-picture-080.jpg   New motor build up..-picture-079.jpg   New motor build up..-picture-078.jpg
Old Oct 29, 2006 | 02:57 PM
Thoroughbred's Avatar
sounds flippin sweet! Whats the c/r like?
Can you shove Alum rods in a 4.6 with more stroke than stock? Just curious...
Old Oct 29, 2006 | 06:15 PM
dan03mach's Avatar
9 Sec. Club!!!
Yes you can.. The C/R should be around 10.5:1...
Old Oct 30, 2006 | 09:52 AM
Bitemark46's Avatar
11 Second Club
You can but ideally you don't want too. That would make the rod ratio worse than it already is. Stroked mod motors really don't make that much more power for the money. The piston would come out of the sleeve enough to wherer the longevity of the motor will be sacraficed. I'd go with a big bore if you want to stay N/A, otherwise just forge the bottom end and keep the same displacement and make it up with boost/spray. -Mark
Old Oct 31, 2006 | 07:06 PM
what about stock ci, stock block, alum internals?
Old Nov 1, 2006 | 08:12 AM
Bitemark46's Avatar
11 Second Club
Ya you can put either I or H beam aluminum rods. Manely H-beams are a very popular choice as they come standard in the 03/04 cobras and can hold alot of power. If it's a N/A motor and you need a lightweight rod the I beams are a good choice. -Mark
Old Nov 1, 2006 | 05:54 PM
eehhhhh......I thought Alum rods didnt have any subcatagories as 'I' or 'H' Beams like Steel rods?
Old Nov 2, 2006 | 10:15 AM
Bitemark46's Avatar
11 Second Club
Sorry, habit, when rods are mentioned I immediately go to steel H or I beams. But they do have alum rods.
http://www.manleyperformance.com/pdf...ds-103-134.pdf
-Mark
Old Nov 4, 2006 | 04:28 PM
Yea I know who makes em.............I dont have any personal experience with Alum rods but my understanding is that they have significantly more surface area than steel rods and I was just curious if anyone knew if they would fit in a stock or 'teskid' blocks?
Old Nov 9, 2006 | 09:01 PM
ehe? Nick? anyone know?
j/c
