2v to 4v head swap
Old Mar 7, 2007 | 02:58 PM
duece_bigalo01's Avatar
Staging Lane
Default 2v to 4v head swap
how difficult is it too swap a 2v motor to a 4v motor? I have a 97 expedition and to poped a head gasket. I'm looking now into maybe putting alittle more power in it cause it needs more then stock. I'm going to go thru and rebuild the whole motor anyway and I'm trying to figure out is swapping out the non pi heads for pi heads would be worth it or should I swap too 4v heads and get it over with. how would the swap effect the computer?
Old Mar 7, 2007 | 07:14 PM
Silver6sp's Avatar
12 Second Club
not worth it at all, the hp gain wouldnt be that great, put new head gaskets on, get a cai and a pcm tune, you will get the same or a bigger gain then a big swap like that
Old Mar 20, 2007 | 09:52 AM
NiCk's Avatar
If it was in a car I would say do it. But for the expidition, juts do the PI swap. Its a lot easier( you can retain almost all the things you have vs. new coolant lines, cam covers) All you'll need is the heads and a PI intake. Everything else will bolt up.
Old Apr 15, 2007 | 09:01 AM
GenIII53's Avatar
If you are JUST looking for a few extra ponies, then no. However if you plan on squeezing more HP out of it, then yes. Depends on what your overall goal is.
Old Oct 29, 2009 | 05:27 PM
assasinator's Avatar
TECH Apprentice
ummm the 4v swap is totally worth it. with a short runner intake, cams, longtubes, pocket ported heads, 380rwhp is average. average.
blackfang
Aug 25, 2011 09:05 PM
mlambrecht82
Apr 12, 2007 11:34 AM
Quick86
May 27, 2006 10:12 AM
ohsofast
Wanted to Buy
Apr 27, 2006 12:40 PM
01steeda
Apr 20, 2006 05:26 PM
