2V-3V Conversion?
is it possible? i know itd take a nice chunk of money but im sure therell be ways especially with HPT comin out with a ford program.
Anything's possible. I don't know if you could drop the 3V in a 2V K-member or not. I doubt the headers would fit, but like you said, it would probably cost a nice chunk of change.
What are the differences between the motors, are we talking completely different block?
probably a 3000 dollar swap
I thought SHM was coming out with a 3v head specifically designed to replace a 2v head without much of the BS associated with swapping out to the factory Ford 3v heads?
if the motors/electronics arent tht different why not a 3v head swap to the 2v, whats so different about the 2?
why not just look into a 2v-4v head swap? It has been done before and the heads should be TONS cheaper...
If you were going to do a 2V coversion, the 4V would be the way to go. Those heads flow really well even in a stock form. |
Are you looking for more HP or just 'retarded' parts? ;)
| All times are GMT -5. The time now is 09:57 AM. |
