-   General Maintenance & Repairs (https://www.modmotortech.com/forums/general-maintenance-repairs-24/)
-   -   Modular Spark plug info (https://www.modmotortech.com/forums/general-maintenance-repairs-24/modular-spark-plug-info-292/)
blackfang Apr 16, 2006 07:22 PM
Figure we could use this..
MOTORCRAFT
PART# / HEAT RANGE
AWSF-32C / stock heat range - copper plug
AWSF-22C / 1 Heat range colder - copper plug
AWSFA-12C / 2 Hea range cooler - copper plug
AGSF-32C/ Recommended for FRPP heads(not sure on heat range)
NGK
PART# / HEAT RANGE
TR-55/ 3951/ Stock Heat Range
TR-6/ 4177/ 1 Step Colder
BP7EFS (PN - 3526) BR7EF (PN - 3346) two steps
R5724-8 (PN - 7317) two and a half steps
R5724-9 (PN - 7891) three steps
R5724-10 (PN - 7993) four steps
AUTOLITE
PART# / HEAT RANGE
764s / Stock
103s / 1 heat range cooler
AR94 / 2 heat range cooler
AR93 / 3 heat range cooler
AR92 / 4 heat range cooler
CHAMPION
PART# / HEAT RANGE
YS-59C / -3 or -4 below stock heat range
DENSO
PART# / HEAT RANGE
IT16 / stock heat
IT20 / -1 heat range
IT22 / -2 heat range
IT24 / -3 heat range
TJs98GT May 10, 2006 10:57 PM
arent the stock motorcrafts platinum?
SOMFormula Dec 31, 2006 01:07 AM
Ummm, I just noticed something, and correct me if I am wrong here....but TR-55 by NGK and the TR-6's are the same plugs I use in my LS1's! So the Mustang uses the same spark plugs?
The reason I am asking, is my '07 is a 3V motor, can I just use my extra set of plugs I have laying around for the Mustang when they are due for a change?
Bitemark46 Jan 12, 2007 03:53 PM
They "may" be the same but better compare the length of threads as one maybe longer then the other and it might hit the piston. -Mark
