Coolant + COP
I had a leak in my coolant system, and I finally traced it to the coolant mod. Turns out it was leaking from the T fitting due to a bad hose clamp. It was leaking hot coolant right on top of the most rearward passenger side COP. I think it's okay, but could any bad come from this?
I think the cops are pretty sealed. If you wanted you could pull it out and clean the spark plug hole, with out taking the spark plug out. You have a gt right? What cooling mod are you refering to? I know the cobras use a by pass for the heads but can you do the same on a gt?
| All times are GMT -5. The time now is 07:34 AM. |
