Starting problem
Old May 23, 2006 | 07:54 PM
HYBRED's Avatar
Default Starting problem
Ever since I installed a MAC CAI, my car has had serious starting problems. The only way to get it to run is to sit in the car and pedal the gas between 1-2k rpm until it decides to idle. After that, it runs just fine.
I would initially just think that I need a tune for the CAI, but last winter, before I got the CAI, the car had the same problem, and I assumed it was just the cold starts it didn't like. Now that it's started the problem up again, I don't know what to think.
Should I look into the tuning, or start checking out the sensors? The car has a lot of miles, so it could just be a bad sensor...like the IAC or something...?
Old May 24, 2006 | 08:52 AM
Pull the IAC and clean everything. Make sure the IAC isn't stuck as well (ie. hold it firmly in your hand, and have someone cycle the key on/off without actually cranking the motor).
Old May 28, 2006 | 01:14 PM
HYBRED's Avatar
Turns out the hose that connects the IAC to the intake...came off. I was not responsible for that part of the install. Luckily, the guys at Oriellys were nice and gave me a peice of scrap hose that worked just fine
Old May 28, 2006 | 08:49 PM
blackfang's Avatar
TECH Resident
Good deal. Sometimes the cai can lean a car out just so you know.
kerndog5.3
Jun 2, 2007 05:11 PM
TJs98GT
Stereo & Electronics
May 4, 2006 09:51 AM
TJs98GT
May 4, 2006 07:55 AM
01steeda
Apr 11, 2006 11:00 PM
TJs98GT
Mar 31, 2006 01:33 PM
