spring isolators?
any idea where I can get some aftermarket spring isolators?
Thanks Tom |
I would think the right ID heater hose might work. My 06 Mustang front strut springs have a plastic piece that is worked onto the spring the same way a hose would be.
thanks guys!
Tom Went with the MM's |
Smmit also sells them. 29 for the front and 19 for the rear. Energy Suspension poly.
something to think about when using the poly spring insulators is that because they are a harder material it will raise the car up slightly compared to the stock rubber ones
