QA1 K member + DnD motorsports A arms = Good???
Old May 27, 2006 | 12:34 AM
Default QA1 K member + DnD motorsports A arms = Good???
So I currently have a QA1 K member sitting on stock A arms and Ford "C" springs. It sits way to low in the front and I have picked up a DND motor sports Coil over kit to raise up the front end a little. While I'm there I figured I'd pick up a set of DnD motorsports A arms, my roommate has them on his GT and they appear to be some quality pieces.
My questions is, will they fit correctly on the QA1 K member? I know that I need to use shims to make the stock A arms work, since apparently the QA1 A arms bushing ends are slightly wider than stock, and I was hoping i wouldn't have to do that with a tubular set. I found a pretty good deal on the DnD Arms, but should I match manufactures with my K member and A arm setup, or would the DnD A arms work???
firedog
Feb 13, 2008 06:09 PM
383ss
Jul 19, 2006 12:28 PM
Just Chuck
May 25, 2006 12:00 PM
blueeyeddevil
Apr 24, 2006 11:39 AM
Wnts2Go10O
Apr 14, 2006 01:16 PM
