Maximum Motorsport LCA How To
Keep in mind these are for the standard LCA
Maximum Motorsports LCA install(MMRLCA-1) Tools needed: 3 jack stands Floor jack 2 1/2" drive ratchet 1 1/4" drive 2 18mm sockets 1 21MM deep socket for the lugnuts 1 13 mm socket 1 8mm socket 1 flathead screwdriver 1 pry bar This can be done using hand tools. However, power tools are recommended to get the job done alot faster. 1. Place the car in Nuetral and the emergency brake is off. Chock the front wheels and jack the rear of the car up and place 2 floor jacks supporting the chasis.3rd jack stand will sit under the axle on one side. 2. Next remove the rear wheels and on the lower control arm remove the Parking brake and ABS cable brackets. Also remove the rear sway bar4 bolts, 2 per side. Some of the 94 and newer cars abs/parking brake bracket is on the swaybar bolt. 3. Now under the vehicle where the LCA mounts into the chasis loosen up the mounting bolt that holds the LCA to the chasis, but do not remove it yet. 4. Place Floor jack under LCA where it bolts onto the axle mount and rear shock.Raise the axle slightly to where the axle is just above full droop. Then remove the rear bolt that holds the LCA to the axle mount. 5. Slowly lower the floor jack to allow the rear coil spring to extend itself to where it can come out of the spring mount and LCA. You can use a chain to keep the spring from shooting out. ( please use caution when lowering as spring is under pressure) 6. Once that is done you can remove the LCA chasis mounting bolt from the chasis. 7. You can use this time to remove the parking brake by removing the safety clip and remove the parking brake cable and slide the cable brackets out and flip the brackets upside down and reinstall the emergency brake cable back onto the rear brakes. 8. Take the LCA and the supplied grease, 3 bushings, metal sleeve. There are 2 big bushings which go on the outer and inner part of the LCA and a smaller bushing that will go inbetween them both. Make sure you install the metal sleeve through the center of the bushing's. You can use a flathead screw driver to pack the grease or put it on before you install the bushings. 9. Now grease up the outside of the bushing and insert into the chasis and insert the chasis mounting bolt, but do not tighten just yet. Re insert the spring and lower isolator and make sure the springs pigtail is facing rearward. 10.Jack up the LCA and using a pry bar or a buddy pry the axle back into position to allow the axle bolt to go into the LCA and tighten the bolts. Once that is tightended, go and tighten the chasis mounting bolt. 11. Install the parking brake/abs bracket back onto the LCA. For the opposite side, follow steps 3 through 11. 12. If you have quad shocks, you can either leave them on or remove them as the MM LCA eliminates the need for them. The bottom bolt where it bolts onto the axle is a 15 mm and the top where it bolts to the chasis is an 18mm. 13. Re install the rear wheels and torque down the lugnuts to around 95 ft/lbs and lower the car off the jackstands. The car feels more sturdier than before and the rear feels more planted. I can feel every bit of the road and the bumps are more stable. Kind of like having an overinflated tire. There really isn't any NVH as many say are supposed to with these arms as they have spherical bushing and all. Maybe I am deaf? Overall I like em and simple to install. A good product for a normal driven car that will be seeing some track time again. If you have any questions, feel free to email me at phil@svt4u2try.com |
| All times are GMT -5. The time now is 09:30 AM. |
