Forced Induction Superchargers | Turbochargers | Intercooling | Water/Methanol Injection
Boosting, but how much?
Old Jan 20, 2007 | 07:39 PM
ThrottleHappy7's Avatar
TECH Fanatic
Question Boosting, but how much?
My neighbor just got a new motor put in his '02 GT. One of the go-fast-goodies is a turbo. The turbo works, but we can't tell how much. He has a boost gauge installed, and if I'm right the needle should be at zero boost but it sits at around 20 below the zero - tap the gas and it jumps up to zero. If the needle sat on the zero at idle you could tap the gas and it would hit just between 8-10 lbs of boost - like it's suppose too. Anybody have an idea of what's going on?
Old Jan 23, 2007 | 11:59 AM
tt460's Avatar
A turbocharged setup will never show boost unless the engine is under load (i.e. accelerating, towing, foot-braking, etc). Just tapping or even revving the throttle in neutral does not produce enough airflow through the turbo to make boost.
Is it a combination vacuum/boost gauge?
If so, it should always show vacuum when the car is at idle or cruise. It will only move over to no vacuum or boost when accelerating.
Has the car been driven on the street since the motor/turbo install?
Old Feb 15, 2007 | 12:27 AM
SuperZ's Avatar
9 Second Club
you can drive around and it seems like you have no turbo.The boost comes on when the car is under load and more throttle
tcwebb
Dec 30, 2007 06:00 PM
NIRVANA
Jun 29, 2006 01:41 PM
klmracing
Jun 7, 2006 09:48 AM
Wnts2Go10O
Apr 14, 2006 01:16 PM
