Gear Change Shop???
Old Apr 20, 2006 | 06:18 PM
00 Z-28's Avatar
TECH Regular
Default Gear Change Shop???
Whats a good and reasonable shop in the Houston area to change r/p on a 04 Mustang?
Old Apr 21, 2006 | 02:29 PM
I've had several installed locally but so far haven't had one installed that didn't make noise. If you find one that does it right let me know.
I had one to lay the ring gear on the dirty floor and pick it up and attempt to install it without cleaning it. Dirt and gears is not a good mix! I have yet to see one use a dial indicator to check backlash.
Old Apr 21, 2006 | 05:45 PM
Blue91's Avatar
Heh, you never came to me for your installs then Larry.
I know someone who could help you out,
Old Apr 21, 2006 | 05:53 PM
00 Z-28's Avatar
TECH Regular
Who? Are they good?
Old Apr 21, 2006 | 06:49 PM
00 Z-28's Avatar
TECH Regular
I found a shop here in Houston that charges $425 for parts (Ford 3.73's) and install, but they want another $425 to correct the speedo......
Old Apr 21, 2006 | 08:19 PM
I'll keep you in mind Fred. Where are you? Thanks...
Old Apr 21, 2006 | 09:28 PM
00 Z-28's Avatar
TECH Regular
Crosby (just east of Houston)
Old Apr 21, 2006 | 11:01 PM
Blue91's Avatar
Spring, but I know nothing about speedo recals.
FWIW, IMO, $425 for gears and install is high, IMO. What do gears run these days?
Old Apr 22, 2006 | 10:30 AM
Smokin'whiteZ28's Avatar
the 8.8 3.73's run any where from about $130.00 to or about $190.00 depending on where you get them and who makes them
Old Apr 22, 2006 | 03:09 PM
Blue91's Avatar
Then yeah, I would say $425 is a rip for gears plus labor, but that's just my opinion.
When I did gears often for money while in school, I would charge $150 labor, and you bring the gears, 2 qts of fluid, and a new rearend cover gasket.
Let's estimate the gearset and fluid runs you $180. You can see how $425 seems like a rip to me, haha.
