Fuel Injection & Tuning DiabloSport | HyperTech | TwEECer | SuperChips | HP Tuners
Changing fuel injectors 5.4 L
Old Dec 30, 2007 | 10:48 AM
kaboom10's Avatar
Default Changing fuel injectors 5.4 L
Has any one changed injectors from the stock flow to a higher flow rate? From what I gather the stock rate is 19lbs/hr. The extra horsepower I expect to make calculates out to about 26-28lbs/hr for the flow I need. Can I expect any horsepower gain/throttle crispness from just replacing the stockers before the mods start? How about tuning the engine with a tuner?
Old Jan 3, 2008 | 11:23 AM
Bulldog Stang's Avatar
Dont change injectors unless you are supercharging and only do that once it is supercharged. Do your fuel system and injectors at the same time as an install with the s/c
Old Jan 3, 2008 | 12:10 PM
kaboom10's Avatar
In searching and reading what I was told the stockers should be fine till the power level goes up from mods (heads/cams/etc.). Found a lot of math to calculate sizes. An increase in pressure would be mre help now. I'm gonna get a reprogrammer for an axle change so I'll add a bit of fuel too. obtw no supercharging is in the future. Never have and never will.
Old Jan 4, 2008 | 12:16 PM
then u will be fine with the stockers .. maybe, and i mean maybe change out to 24 lb when u do a heads/cam swap with a ported intake ...
Old Feb 14, 2008 | 02:23 PM
kaboom10's Avatar
I've started taking the inlet/exhaust restrictions out and max tuned it on 93 octane. I've done 0-60 times using stock A/F @ W.O.T. then went to 10% richer setting and no diff at all. Am I reaching the stockers limits? I'd like to change to 24's for the better spray pattern at least. obtw the mpg's went up 20% (2.0mpg) with my foot in it.
Old Jun 8, 2008 | 08:21 AM
kaboom10's Avatar
I switched to 21lb. units for the heck of it. I thought I'd try Accel and it has a crisper throttle response than before. Might just be the spray pattern? It was worth it to me for the money spent. I changed the values in the tables to match them also.
Old Jun 9, 2008 | 03:34 PM
autosay97's Avatar
There are no gains to be made with fuel injectors alone. Kaboom, what are your plans for the truck? Is it a pi or non pi motor?
Old Jun 9, 2008 | 06:45 PM
kaboom10's Avatar
It's a PI engine being a 2002. I've been tuning on the MAF transfer function table to bring F/As in line.
Old Jun 9, 2008 | 07:39 PM
autosay97's Avatar
Had much luck?
autosay97's Avatar
oh and what are you using for tuning? Tweecer? SCT?
